IFIX DI tag to open picture
Well it took me an hour, but i was able to copy and paste some scripts from other objects to make it work. I really need to learn VB.
I was going to say that this can probably be done with a scheduled action triggered by that DI.
I wouldn't do it this way though. Why not open the pop up, put text in box, click confirm, have a msgbox come up asking if the person is sure about it and then execute. Much simpler to do and doesn't rely on PLC comms and state (which can cause havoc on a SCADA when done like this).
I'm going to have to try your way.
The confirm/abort pop is for after machine has started moving. The engineer wants the operator to have to confirm they want the machine to continue to move every foot of travel.
I don't know the application, but that sounds like a nightmare.
How long does that foot of travel take? A lot of people assume that by putting more confirm buttons, that the operator will read more... when in fact is the opposite.
Just today I had the same discussion where I was asked to put such a pop-up and when asked if the function itself could be interlocked, no one even considered that as an option.
Cardosocea, a foot will take a over a minute. The PLC was programmed to require acknowledgement every foot. I can't change the PLC logic at this time since its coming from a contractor.
Thanks everyone !
That sounds excruciating... 8 hours, assuming production goes smooth and it takes on average 2 minutes to confirm is 240 clicks.
Hope no one makes a mistake in the future and someone decides that it now needs to be double click to confirm.
Hi I'm working on IFIX 5.5. I need to open a operator prompt to be visible based on the status of a tag that is read from the plc. When i say...
20
1,456
Hello, During runtime I change values of some internal tags (i.e. F_CV of DO tags). And I want them to be saved when I switch runtime off, and...
5,459
Hello everyone, I am a beginner, so please let me know if I am wrong with certain terminology or missing useful information. I am having a...
3,128
My iFIX database has alot of tags. It also has alot of screens. Is there way in the Database or way to search which screen the tag is being using on?
2,577
I am trying to simply display a PLC string tag value (text) in a VBA control (msgbox or anything...just to get it working). The following code is...
5,980
