Proficy iFIX Database Manager Tag addressing from Logix
mya_100
May 2017
San Angelo
Hello everyone,
I am a beginner, so please let me know if I am wrong with certain terminology or missing useful information.
I am having a hard time with the syntax of a tag element to put into iFIX to get a real-time current value. I am trying to pull the tags from a Allen Bradley PLC. I am using an IGS Ethernet driver for this.
I keep getting question marks as my current value and I don't know why. On iFIX I have been using Analog Input as my type.
I attached an image of one of the tags I am trying to do. It is an element tag.
Tag element name: RefeedData[1]
Element Data Type: DINT
Tag Data Type: DINT[20]
Tag Scope: Controller
Dim 1=0
Dim2=20
I don't need the bits, I am just trying to get the value from the element itself. Is this possible? How is the syntax supposed to look like?
Please help me. Thank you.
Mya
I am trying to simply display a PLC string tag value (text) in a VBA control (msgbox or anything...just to get it working). The following code is...
5,980
Hi I want to press a button on the HMI screen and write to a bit within an Integer within a control logix PLC. The iFix version is 5.5 and using...
2,398
Hello, During runtime I change values of some internal tags (i.e. F_CV of DO tags). And I want them to be saved when I switch runtime off, and...
5,459
Hello All, Can any one assist me with trial version of PROFICY IFIX software as i am new this. Thanks,
1,937
So, Im a wastewater operator and also a digital designer/ web developer and im trying to learn Ifix 6.0 or 5.9 but I cant find any resources to...
1,344
