Incorrect PLC answer
Becouse I like doing things of this kind.
You then better like cleaning up too.
No kiddin'. The cable you can buy is guaranteed to work. If it doesn't you get a replacement. With a home-built cable the cost is way higher if you count the time needed to solve the problems.
Regards,
I have a 7 slot rack with a SLC 5/03 controller,2 input cards, and two output cards I am trying to emulate a PLC that is out in the plant, so I...
4,537
Good day. I encountered a problem when calibrating a channel on the IF16H module. The module is located in the local backplane along with the...
751
I have some programs that i received from 1 of our programmers whos installing a new machine in our plant. He added them to a external hard drive...
1,362
Hi, At the moment, If the user fails to provide a valid username/password, the image attached appears "Invalid password or user name. Logon has...
1,580
Hi all, I am currently having an issue with 3 HMI panel view panels with the alarm list showing the incorrect date and time. It shows up as the...
2,276
