Industrial Firewall recommendations
MOeZ
Nov 2009
singapore
101
Hi Folks,
could any recommendations for Industrial firewall which working good with OPC protocol?
Appreciate that in advance.
If you really want an industrial firewall made to inspect industrial protocols I would recommend Tofino https://www.tofinosecurity.com/sales/tofino-hirschmann
Most other firewalls are just routers beginning to sprout a little chest hair and most have Simple DMZ and ACL functions with SPI capability which your home linksys router can do. The industrial is in a more rugged case but it's what's under the hood that counts.
On anything you really care about keeping secure make sure the firewall you choose can do DPI Deep Packet Inspection and can handle the inspection of traffic from an industrial protocol which is different from TCP /IP protocol.
Hi Folks,
Any industrial firewall should work well with OPC, the trick is setting it up right.
Thanks all.
Thanks all for your recommendation. sent query to supports. OPC use each time in dynamic port (XXXX~XXXX) that make firewall unfriendly. i have concern of speed too when use firewall.
Hope they reply my query soon.
Hello, I am looking for a solution to remotely access any kind of device securely across the internet. I know this has been done in piecemeal...
22
2,242
Hey Everybody, I resigned from teaching, to pursue an IT career, and my original objective was to prepare for and pass a few entry level certs...
581
I'm working on an application and have hit a bit of a snag. I need to find an industrial touchscreen display that can: - Tolerate down to -40C...
760
I swear I post this yesterday but can't find it. Don't see any notification about the post removal either. Maybe my memory is malfunctioning...
2,573
