Internet up/down load for SYSMAC OMRON CS1G-CPU42H
I thought the DIGI unit was a serial pass through.
Don't you just need to configure CX-Programmer for the
correct serial port number?
May be wrong, been a while since I worked with one.
Let's back up a minute. I must have missed something.
Just exactly what are you trying to do?
How is the DIGI unit being used:
What two devices are you trying to connect?
Which device is connected to the serial port on the DIGI?
Sorry if I missed this, but I am a bit confused as to what we need to accomplish.
I'm not sure but try this
1-In the project worspace at the left, you have the Plc icone with the model(CS1G) and offline. Double click on that.
2-Under "network type" select ethernet
3-than click on setting.
4-In the pop-up go in driver. You can enter you're Ip adresse there
5- Now try to connect online.
I think that what you are missing is the Digi driver (Realport software, if I remember) that makes that converter on Ethernet appear as a serial port on the PC.
Then you set the programming software (CX Programmer ??) for Host Link communications.
The PLC serial port also has to be set for Host Link communications, matching the settings made in the Digi converter.
I am going to switch PCs and see if I can find the document that I wrote on this setup.
Hi, sometimes I have to go on the net via a plain old modem (for example to check on PLCs.net when traveling :) ). It is really irritating that...
18
4,777
This is more of a multipart question involving home networking and I have limited experience in computer networking. The first objective is to...
338
Engineers: So, we are supposed to do some mods to the controls at a pumps station with a SLC 5/03 and it needs to communicate with another new...
2,505
I have a pc running windows 10 pro that is on a network that does not have internet access. I need to put RSLogix 5000 on this computer for a...
4,752
Hey all, This question is identical to questions that have been asked by many many others before me. I am not happy with the answers i found over...
18
6,929
