vinukrishnan
hi,am using intouch scada version 10
first of all i want to inform you that i am having little knowledge in intouch scada version 10...but still find the way to make the required windows.
problem:-
i am having two window one is for monitoring the plant and the other is for monitoring alarms .and when they are running i want switch between these two window example using push button(named it as alarm) which is created at the first window and when i push this button i have to switch from my first window to my second window(in which alarms are displayed)...in the second window also there is a switch using that i have to move from second window to the first one ......that means i should be able to view any one of the window during running by just pressing push button.please give a solution to establish that kind of switching between the windows
if any more information required please inform me..thank you
problem:-
