It is possible to make something like this in SCL
BoSChoW
Apr 2006
Nova Gorica
107
Hi all, yet another problem. I send through the OP7 choosen steps from 1 to 4 and the choosen inputs from 1 to 8 to the DB steps.steps01 .... steps.steps04 and inputs1.inputs01 ... inputs3.inputs08. The plc inputs will be stored in the plc_inp.inp01 ... plc_inp.inp08 DB. It is possible to write something like this in SCL?
const
step01:int:=1;
step02:int:=2;
step03:int:=3;
step04:int:=4;
end_const
var_input
input01:bool:=false; //decleared in the simbol table
input02:bool:=false; //
input03:bool:=false; //
input04:bool:=false; //
input05:bool:=false; //
input06:bool:=false; //
input07:bool:=false; //
input08:bool:=false; //
end_var
var_output
output01:bool:=false; // decleared in the simbol table
output02:bool:=false; //
output03:bool:=false; //
output04:bool:=false; //
end_var
var
step:int:=0;
end_var
plc_inp.inp01:=input01;
plc_inp.inp08:=input08;
begin
IF avtomatic then
begin
case step of
1: output01 and not output02:=(steps.steps01=step01) and
(plc_inp.inp01=inputs1.inputs01) and (plc_inp.inp02=inputs1.inputs02) and (plc_inp.inp03=inputs1.inputs03) and
(plc_inp.inp04=inputs1.inputs04) and
(plc_inp.inp05=inputs1.inputs05) and
(plc_inp.inp06=inputs1.inputs06) and
(plc_inp.inp07=inputs1.inputs07) and
(plc_inp.inp08=inputs1.inputs08);
2: not output01 and output02:=(steps.steps02=step02) and
(plc_inp.inp01=inputs2.inputs01) and (plc_inp.inp02=inputs2.inputs02) and (plc_inp.inp03=inputs2.inputs03) and
(plc_inp.inp04=inputs2.inputs04) and
(plc_inp.inp05=inputs2.inputs05) and
(plc_inp.inp06=inputs2.inputs06) and
(plc_inp.inp07=inputs2.inputs07) and
(plc_inp.inp08=inputs2.inputs08);
3: output01 and not output02:=(steps.steps03=step03) and
(plc_inp.inp01=inputs3.inputs01) and (plc_inp.inp02=inputs3.inputs02) and (plc_inp.inp03=inputs3.inputs03) and
(plc_inp.inp04=inputs3.inputs04) and
(plc_inp.inp05=inputs3.inputs05) and
(plc_inp.inp06=inputs3.inputs06) and
(plc_inp.inp07=inputs3.inputs07) and
(plc_inp.inp08=inputs3.inputs08);
4: output03 and not output04:=(steps.steps04=step04) and
(plc_inp.inp01=inputs4.inputs01) and (plc_inp.inp02=inputs4.inputs02) and (plc_inp.inp03=inputs4.inputs03) and
(plc_inp.inp04=inputs4.inputs04) and
(plc_inp.inp05=inputs4.inputs05) and
(plc_inp.inp06=inputs4.inputs06) and
(plc_inp.inp07=inputs4.inputs07) and
(plc_inp.inp08=inputs4.inputs08);
END_CASE;
ELSE output01:=false; output02:=false; output03:=false; output04:=false;
END_IF;
And also any suggestions are welcome, thank you for your time and help, regards.
Hi, on some PCs that we use at customer locations and that are running non-critical programs, and are running with 'normal' Windows i.e. not Win 7...
1,941
Hey so I have an issue that is driving me insane. I have 6 AB powerflex 527 drives configured in a DLR network over CIP Safety. They go back to a...
1,741
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
249
Hello The plant is running and there is no shutdown nowadays therefore I can add 1734- AENTR and its card while PLC is in Run? I do not wanna...
370
Folks, I have a client with an old ABB Advant / MOD300 system (v14.4). Around y2k I installed the ABB Industrial IT MOD300 OPC Server 1.1/2...
203
