Job Interview Test
dYoast
Mar 2008
Kansas City
252
Does anyone use a test to determine if a job candidate has some actual skills? If so, could you share some example questions?
I need to evaluate an internal employee to determine if he would be a possibility to step into a higher capacity. The test will help eliminate any bias toward that employee or other candidates.
Thanks.
Seen that the person is an internal employee, his/her abilities and commitment should be known.
From a technical point of view, give him/her an appropiate test covering his/her current position, and add the required skills and knowledge required for the new position.
Then, add a few higher level tests, to determine if the candidate has the insight, currently, to progress to the next level.
But from my experience, test conducted in an "stressed" environment does not yield true results. "Hidden" test will always show actual skills and knowledge.
seen that the person is an internal employee, his/her abilities and commitment should be known.
But from my experience, test conducted in an "stressed" environment does not yield true results. "hidden" test will always show actual skills and knowledge.
x2
My thanks for the replies. The thought of searching did not cross my mind, so I apologize to all for that oversight.
I agree with this completely. There already is an aptitude test that HR uses for our maintenance department. Just because someone passes this doesn't mean he/she can then adapt that aptitude to actually troubleshooting and fixing machines.
I have been invited for an interview @Beumer group (Company) During the interview they will also ask me to make a program anyone here working in...
19
6,316
So, I have my first real job interview this week...and I'm pretty nervous but also VERY excited. Just graduated as a junior industrial automation...
18
6,807
Good Morning Everyone, I know there are tons of control engineer, PLC programmer and president of some automation companies on this forum. I am...
34
11,768
The company I am going to interview for is using mostly AB, but they want to convert over to Siemens. I haven't played with Siemens in about 2...
2,256
I have been waiting for this for a while so i could use some advice. I am going in for an interview for an instrumentation Technician with a...
2,140
