Kinetix 300 enabling on startup
lurby
Mar 2005
32
I am controlling a Kinetix 300 drive with a Micrologix 1100 using msg instructions. So far all is well. I am trying to put in as many bug fixes as I can before I ship the machine out.
I am using a PLC output for my hard-wired drive enable (29-26). When I cycle the PLC power and that hard-wired enable opens and then closes again I see the drive try to enable for a spilt second and the un-enable again. That it okay because I do not have any other signals going t the drive so the motor does not turn. It does cause a problem if my STO switch is open at the time. The STO on the drive is wired through a door safety switch. If that switch happens to be open when the PL power is cycled and the drive tries to enable the drive will go into a fault E39. Not the end of the world. I can clear it with a fault reset.
What troubles me is what could be causing it. It must be something that I have set in the drive setup because it does it even if I open and close the hard-wired enable without the PLC.
Anyone have any ideas? Is there something in the drive that does a split second diagnostic to see of the drive can enable properly? I hate little glitches like this that do not hurt but are just a pain...
Thanks in advance.
That should not happen; generally speaking, no PLC Output should turn Off/On upon a power cycle; there should be more than one condition for any Output to be energized.
It is a combination of my previous observation and the chosen control method- Explicit Messaging on a ML1100; yes, the manufacturer has documentation examples, however, personally, I would never use a servo-drive within a MicroLogix controlled system, Ethernet networked or not; the 'explicit' nature of the implemented control communications is barely implemented functionality and nothing else; obviously accuracy and safety were secondary considerations to cost...:D
Have a system that has been running for over a year and all of a sudden getting a ExcessiveVelocityFault on one of the drives when the MSO command...
151
Hello PLCS.Net Forum, First time posting. Let's assume I am a novice. BASIC PROBLEM: My servo/linear piston is no longer zeroed to the...
229
Hello. I have a few machines that use Kinetix 300 (each machine has two drives). Both drives on one of the machine keep losing IP address. They...
104
Hello, We have had a machine running for the last 10 years. It has 2 x Kinetix 300 drives. Around a year ago, one of the drives failed. We were...
432
Hello, I have a die punch machine with servo motor for material feeding. I'm using Kinetix 5300 to control the feeding system. Every recipe have...
529
