Kinetix 300 versus Ultra 3000
Switek
Nov 2008
Cork/Ireland
25
Hi all,
I am new to motion control and just wondering, what are the differences between those to drives.
I need to find out which of the drives will meet my requirements. The application is to control the stroke of dosing pump, so as I can imagine there is only one axis to control, which would indicate to me that Kinetix 300 can do it.
Does Kinetix 300 need external encoder which has to be conneced to the PLC separatelly or is it in-built to the drive?
Rockwell engineer when went to site proposed Ultra 3000 with the sercos module ect.
Are there any specific reasons why Ultra 3000 will be better than Kinetix 300?
I went trough the manuals and to be honest I can't see the reason for using Ultra 3000.
To what application Kinetix is mostly used and to what application Ultra 3000?
Thanks in advance for any hints,
Switek
Have a system that has been running for over a year and all of a sudden getting a ExcessiveVelocityFault on one of the drives when the MSO command...
148
Hello PLCS.Net Forum, First time posting. Let's assume I am a novice. BASIC PROBLEM: My servo/linear piston is no longer zeroed to the...
223
Hello. I have a few machines that use Kinetix 300 (each machine has two drives). Both drives on one of the machine keep losing IP address. They...
100
Hello, We have had a machine running for the last 10 years. It has 2 x Kinetix 300 drives. Around a year ago, one of the drives failed. We were...
430
Hello, I have a die punch machine with servo motor for material feeding. I'm using Kinetix 5300 to control the feeding system. Every recipe have...
527
