Kinetix 6000 MSO Shutdown issue
mrdmrd
Dec 2002
Nebraska
77
Hello everyone
I have got another puzzling problem for you.
I have a machine that has a total of 5 Kinetix 6000 servo's on it. The problem that I am having is that randomly when the CLX issues a command to the servo's to enable (MSO)the servo in the # 4 node position will go into a Shutdown state.
This does not happen each time sometimes it will enable correctly. I know that it is not an issue with the way that I issue the MSO instruction as all of the other servo's are tied to the same set of conditions that trigger the MSO and none of them have these problems. I have verified that the Safe Off part of the system is working correctly and that there is a couple second delay between the safe off coming back online and the MSO instruction.
For additional information the motors that are tied to the Kinetix are AB 1326AB motors. We have tried to switch the Kinetix Modules for nodes 4 and 5 around to see it the problem moved with module, it does not it stays on node 4. We have switched out the SERCOS module in the CLX. No help. We have even went as far as to change out the power rail, again no help.
I do not know why the servo is going into shutdown mode. Before the MSO instruction is issued the servo is in a READY state. As soon as the MSO is issued the state changes to SHUTDOWN. I do not have any Shutdown commands programmed in the PLC and also do not have any fault actions set to Shutdown. After the servo reports back that it is in shutdown the MSO instruction error's with a code of 7 (Attempted to enable a servo when it was in a shutdown state.)
We do not get any error codes on the servo it always stays at a communication state of 4 (normal) it simply will not enable.
I also have 5 other machines that are programmed with the exact program and the exact same control wiring that do not exibit any of these problems.
Thoughts?????
I am sure that I forgot some details that you may need so if there is anymore information needed let me know I will try to get it.
Nevermind
Please cancel the above request for help....
I just talked with the plant personnel today and after all of this time of beating my head against the wall someone let it slip that the problem did actually move during the original troubleshooting effort and stayed with the Kinetix module and not in the same node location.
I have recommended that they remove the module that now resides in the # 5 node location and replace it.
Thanks anyways.
Howdy guys - Looking for some insight on the MAM instruction. Had an interesting one today: I performed a controller upgrade on an older system...
446
Hello everyone: I am looking at the possibility of migrating Kinetix 6000 to Kinetix 5700(460V 3 phase). Reviewing the drive catalog, I have the...
1,160
We have two similar pieces of equipment, one of them uses a Kinetix 6000 for an axis and the other uses a Kinetix 350. When power is removed...
853
Hello All I have a machine built in 2013 but never commissioned. I have it almost complete. It has 2 Kinetix 6000's with a CompactLogix L43 with...
1,206
Trying to configure the 2nd drive on this machine. It is being difficult. I have the gains speed encoder data all with good data. when I try to...
1,857
