Kinetix 6500 M07 incremental loss
Deepak Jadhav
Apr 2024
Vapi
Dear team,
We are constantly facing M07 incremental loss on one of our kinetix 6500 safe torque.
We have changed Servo motor (MPL-B4530K-MJ72AA) within 2 months we are again facing this M07 issue on the same servo.
Kindly help if any one has any root cause for this problem.
Did you change the encoder cable or the encoder breakout connector at the drive? Intermittent is likely a loose connection on the breakout board, a cold solder joint on the board, or a faulty cable. I'd swap out the connector as a first step. Grounding issues can also cause this, so make sure you are following the ground and shield guidelines in the install manual.
Loving AB right now... We have an Allen-Bradley 2094-EN02D-M01 Kinetix 6500 servo drive that once had safe-speed monitoring which was eliminated...
164
Hello, I encountered a problem with the kinetix 6500 drive, error code s22, loss of 3 phase voltage. After disassembling and replacing the thermal...
196
Hi everybody, I am having an intermittent issue with a Kinetix 6500 drive. The fault i get is a SAFE FLT 05, described as GuardFeedback1Fault in...
918
A line in our plant has always had an issue where everytime the jar filler stops/restarts, it wastes 5-8 bottles because of underfills. FWIW, the...
1,842
Customer is moving machine, and down sizing it. It has a 6500 rack and they will be removing 4 of the servos. Can I put the slot fillers in the...
1,462
