Kinetix Motion MDAC / MAM
Mike_RH
Sep 2006
Toronto
896
Can anyone provide a description of the Event Distance and Calculated Data Parameter function in a MAM instruction when used with the MDAC?
I have it doing what I want, but can not find much documentation on these parameters. I understand the Calculated Data is a return value - but what is the meaning / use?
With the EventDistance, I change the values, and get different calculated data, but the same motion.
I have read the Motion Instruction set manual and searched the Rockwell knowbase. Can't find anything . . . of substance.
All comments appreciated.
Hi Mike, Thanks for response - I am not using it on a project, but as it is a feature I am not familiar with I am trying to figure out how it works.
Curiosity kills more than just cats! :ROFLMAO:
Everyone, I am having an issue with our current program and need advice. Our current setup has 4 servos running on a pusher chain conveyor. The...
479
Hello everyone, Ho do I go about making changes to a "Motion Axis Parameter" e.g. PositionScalingNumerator that is currently grayed out in the...
1,390
Hi All, the drive was changed recently and now having issues with the servo where it acts a bit strange. I know I need perform an auto tune. I...
1,588
I have two 2198-P070 bus power supplies for that I’m using for four Kinetix drives, 2 drives per power supply, all controlled by one processor...
1,435
Hi all, I wanted to share with you an issue that I had with a Kinetix 5500 servo drive. There was a mechanical problem with the axis, and...
2,854
