KTP 1000 limitatation (WinCC Flexible)
manmeetvirdi
Oct 2004
India.
750
Hi there
Iam using a KTP1000 10' for a project. Actually its a very basic device with limited functionality.We can use maximum of 30 tags in a screen.
There are 28 roller convyeors and containers will be moving on them.What I want to achieve is conveyor status (shown in different colors @ events like motor trip, jam etc) container status (filled, empty, present, not present) and container ID all through one tag !!
Conveyor status and container status can be shown with one tag and I have tested it, but I cant figure out how to display container ID with same tag. Container ID will be between 100 to 255.The tag which Iam using as of now is double word.
Can it be done anyway using tag multiplexing or address indirect method?
I have no experience with the KTP panels.
Do they support array tags ? Can you link array tags to the animations ?
If this is supported, then you can easily animate many more objects on the screen.
I can see that there are several other "interesting" limitations.
Max 30 "fields" (?) per screen.
Max 5 "complex objects" (??) per screen.
30 tags or animated objects on a screen would be a dealbreaker for me.
JesperMP thanks !
Using array is a good idea and to my surprise KTP1000 does support array ! But dont know how it will behave once i have loaded the project using array. Lets see.
Hi all , The problem in brief I had HMI KTP100 DP ( Italian ) , i had the software of the screen in English (TIA 13 SP1) and i wanted to change...
7,373
Hi, I have a question why he can not at the panel KTP1000 Basic DP tag used both for object and at the same time for a recipe? For other panels me...
1,880
Hello People, I need your expertise of Communication problem. I am having a KTP1000 DP and ABB PLC which I need to communicate. Now ABB wants...
3,682
Hello, I am doing a project that requires the use of recipes, but I am having some difficulties. First I am trying the code with simulations and...
822
Our a customer has got S5-95U Plc and OP17 Hmi.OP17 is defect.They want to use a new generation Siemens Simatic basic panel (KTP400,700,1200...
1,983
