KWH Meter
desuhardi
Oct 2005
Indonesia
46
Hello all,
I want to make kWh record with PC. kWh meter is Merlin Gerin, with 1 impulse of 200ms every 10kWh. Is it possible to connect this pulse to digital input of PLC, like as Mitsubishi FX, Toshiba T1 or others ? Or any other idea how to get kWh data to PC ?
Thank you
Sure you can. The impulse is long so it should not be missed. Use the pulse to increment a counter then use that counter value as the number of 10kWh logged. That value would be stored in the PLC and downloaded to a PC via whatever software you choose, like a SCADA or HMI package.
If the meter has communications available then you would do a direct connection to a PC and using appropriate software you would transfer the values. You would need to have the correct drivers and formats to do this.
I know this doesn't answer your question, but if you happen to be concerned about motors I know that a lot of VFD's now have KHW meters on them. If it is motors you're looking for KWH and they're on VFD's that show KHW, you could get more granular in your KHW data collection. Your drives would have to also be on a network of some sort to get the data.
I've often wondered how accurate the KWH meters on VFD's are...Perhaps I'll start another thread instead of hijacking this one.
Greg
Dear All , We are reading from Energy meter over modbus the kW and KWH in plc . Now customer wants the KWH consumption / day and month , but the...
1,534
Hi all, I am having trouble communicating with a Schneider kWh module that is fitted with an M-BUS module. I have successfully used the ADF...
2,669
Dear All, I have a little problem in reading data from Power Meter to Vijeo Citect v6.0 I'm using Schneider PM810MG for Energy reading from...
3,305
Hi. I have a Kwh meter with puls output. it give 1000 pulses for each Kwh. If I have the meter measuring 1 kw load, then it takes 1Hour to...
20,269
I want to calculate the energy consumed from instantaneous power. Can this be done using the TOT block with timebase set to Hour?
716
