.LAD extension
I'm not saying for sure what you have, but *.LAD was the ladder file for ICOM AI-2 software for the PLC-2 controllers.
An AI-2 project consists of more than just the LAD file.
.ADR
Index for description text.
.CFG
Program Configuration Data (plc2ll0.cfg)
.CNT Table of contents
.DEL Deleted unused instruction descriptions (ASCII delimited format)
.DSC Instruction description text
.ERR Error message storage
.IOM I/O configuration file
.LAD Ladder Logic
.LIB Blocks of rungs saved to disk
.PRF Program revision history file
.RPD Rung/page titles file
.RPI Index for rung/page titles
.SCR Custom data monitor screen
.RDT Report Header
.SYM Index for description text
.XRF Cross reference file
.XRI Index for cross reference file
.001 Ladder backup file (oldest)
.002 Ladder backup file (next oldest)
.003 Ladder backup file (highest number is most recent)
GE Logicmaster (DOS version) had a .LAD file.
Which you can import into Directsoft.
GE Fanuc Logicmaster software for Series One, Series Three, Series Five and Series Six used .LAD as the file extension for the ladder logic files. As others have mentioned, they are not the only brand to use that extension, but if that's the only file you have, it's enough for those GE Fanuc models.
Post it here and we can try to open it and see what works. You will have to rename it with a different extension. This forum won't accept attachments with a .LAD extension.
It might be a PLC Ladder Logic of EZ PLC, from EZ Automation, a division of AVG Automation.
In the previous years, For the PLC Ladder logic when we save on the hard disk the PLC program used get saved with .lad, .isa, and few other extensions along with .LAD.
Goto www.ezautomation.net or you can call on their Toll free No. - 001 877 774 3279.
Have a try ... I am not 100% sure.
Harsha BS
Post the file and someone should be able to determine the PLC type from the file. I think that information is embedded in the file. As Steve said, post it with a different extension, like .plc.
Are you trying to replace the PLC or troubleshoot it?
I remember many years ago, I used a PLC with .LAD extensions, there was also another extension that went with it which was held in the same directory and I believe it was for an IMO Nexus, blue box. The software was Caps6 which I am sure is still available and free to boot. It was also what I learnt on, so hence why I can remember it!
Hi.Can I convert the block written in stl mode below to ladder mode? L #InOctet SLD 3 L #InBit OW T...
566
Hi, does anyone have experience with the Off Delay Long Timer function in GX works 3, I need a PV greater than T#2147483ms If I use Long Timer...
1,233
i hope you could help me to convert the network Stl to lad it's apart from program of machine and i try to find solution for the reason of error...
1,946
Not very often I ask for help, but this one has got me stumped. There are two ways to indirectly address memory areas in Mitsubishi PLC's. Using...
4,492
Hello, I'm working on a program I migrated from S7 v5.6 to TIA v14. I am failing the consistency checks on my safety program with the following...
20
4,603
