Laser beam sensor
Goody
Apr 2002
Huddersfield W Yorks UK
1,081
I need to send a light/laser (even maybe ultrasound) beam across about 70M (80 Yds) to detect a moving carriage.
The gap between can be quite steamy in winter not too dense but drifting across the beam path.
Does anyone have any experience with a reliable sender/reciever that would see for this distance in these conditions?
Do you want to detect the exact distance of the carrage? If so with what resolution? Does the carrage have a power supply? If so maybe a wireless comm for the carrage to the controller might do??
I'd love to know more details..
No, I dont need anything as sophisticated as the exact distance - just whether the beam is made or broken.
This carriage runs on rail tracks and fills and empties ovens (steam ovens - hence the drifting steam)
While the carriage is in the ovens (22 seperate ovens curing concrete blocks) the beam will be made and while it is travelling to and from the ovens it will be broken.
New safety gates have been fitted to this area with electro solenoid locks and if a gate is opened and the carriage is in an oven it will be allowed to come out, but once the beam is broken (meaning it is clear of the oven) the power will be cut to stop it travelling on the rails.
Goody,
I'm sorry, I can't comment on the steam. However, considering the pitfalls of the other possibilities you have considered, (distance, alternative beam/sound paths etc) I'd say a laser is the only means you would stand a chance with.
Regards,
Nigel
Hi I have a yaskawa gp7 robot arm which I am going to use for machine tending with a cnc mill. Is it a good idea to buy a SICK laser scanner for...
249
Hi experts, I hope you're all having incredible days. I'd really like to utilize this sensor for a customer application, but the issue is that...
17
18,861
Good Afternoon , We have a few Datalogic Laser Sentinal Scanners . We have 2 that are pointing upward toward the ceiling . Roughly , within...
1,054
how to program a laser level sensor to a cooler tank with an AB plc
1,327
Hi everyone, I don't know much of PLCs but it happened that i need to connect Leuze AMS358i Ethernet laser measurement to Productivity 1000...
1,067
