Hi All,
I'm a little late checking in here -- the stuff from AD arrived around 8:30 today and I've been like a kid on Chistmas morning!
While looking over the DL06, a question occurred to me. When I ordered it with the DC outputs, I was fairly certain that I would be interfacing with a stepper system. If I switch to using an AC drive, are the DC outputs still compatible?
Responding to some of the posts since last night:
Originally posted by ArikBY
...this kind of systems don't work in 2 directions.
Unless you're going to have a feed motor.
I was a bit taken aback by this at first -- you mean that you can't reverse an AC motor with an inverter?? Then I realized you probably meant that it's not practical to reverse the wire travel (at least not very far) because it won't go back on the roll (without some kind of positive drive on the roll). Of course, the small reverse movements necessary to correct an "overshoot" on the encoder would not be a problem.
By the EZ you will input:
Length
Deceleration length (it change according to the pulling speed)
Size of the batch you want.
and some other counters if you want.
Arik, I'm not quite sure what you're saying here. This would be something the
machine user would input?
Originally posted by Eric Nelson
...you might be happier with a separate 'JOG' pushbutton button connected to a PLC input. If you use an EZ-text key to jog, it won't be as responsive due to communication delays between the EZ-text and PLC.
Yes, this is a good point. Also the membrane PB's on the EZtext don't have the right "feel" for a jog button. I prefer a standard 30mm oil-tite PB for this function.
Thanks for the advice, Arik and Eric, about the issues with the GS1. Since I have no experience with
any of them, I will take your recommendations to heart.
Originally posted by elevmike
I still go for forward and reverse. This would enable you to jog the end cut back out of the traction drive unit with out having to grip the wire with a plyers or someting. I understand the chance of overshoot is very small, but I just think that for the trouble, all it would take is programming, why not add it?
I tend to agree, at this point. But it's not something that has to be decided once and for all right now. I'm still leaning toward having an air cylinder and solenoid valve control the tension rollers on the traction drive. Maybe a safety issue -- when the E-stop is pushed, the valve output is killed, and the drive pressure releases.
I saw in the AD catalog the GS1 has a model that will operate from 115vac 1 phase. Please dont get too excited about that model. I would reccomend that the main power supply for the drive be at least 220 1 phase. 3 phase is better.
The only reason I'm leaning toward the single-phase is that my customer wants this machine portable, but I think he just means that he doesn't want a hard-wired conduit drop. He would like to be able to move it around just in the area where it's normally used. I am going to see him tomorrow, and I will ask him about this. I'm fairly certain we could use three-phase, if that makes for a better running machine.
BTW, I got a call from my customer this morning telling me that the 500 lb. roll of wire arrived. "Yikes!" Now he's wondering if this is going to work. He said that the wire was not rolled very uniformly, and the design for the unreeling unit may have to compensate. He seemed a bit apprehensive. (As a point of reference, has anyone here worked on one of those lawnmower recoil-starter springs? Picture one of those that weighs 500 pounds!) Here we go...
