hotrod said:
Hey thanks rsdoran, I'll be at plc's for Idiots.
You said it, I didn't. NOTE, your question had nothing to do with a plc.
Well here it is, we got an a/c motor hooked to a d/c inverter,
NO, you do not.
Technically I am the last person to be nasty etc, but when warranted I can be.
Well they found that the encoder was out of phase, It has an a+ and a A- wires that have to be reversed when the phase of the motor is changed. It is a lenze 9300 series drive hooked to a Lenze 1.7 kw motor. they called lenze this morning to get the scoop on the encoder. thanks guys!!
An encoder uses A, NOT A, B, NOT B, Z, NOT Z but not A+ and A-, what I suspect is a tach generator. Overall I think you do not have a clue though, if the motor reverses any feedback device should not have to change wiring physically.
ALL through your discussion you never mentioned the drive or motor being worked on or that it was a new installation BUT did state it was a new problem that had been running properly. Whether tach or encoder it will NEVER just, out of the blue, be out of phase OR magically move its wiring to the wrong connector.
Personally I do not care what you think about what I say, you should feel good because I am one of the NICE ones in most cases.
As I stated before, use the proper terminology and state the problem fully. If you do not know then learn.
