I just got a new job assignment: Global Laboratory Facilities Engineer. With this, I will need to get back into the automation arena a lot deeper than the sporatic projects I have had in the last twenty-five years. I have been lurking on this list for the last week or so and it looks like you are a great bunch of knowledgeable, helpful guys (and gals if any are out there) that might help point me in a direction as I reaquaint myself in machine controls.
I have an immediate application that is begging for a PLC but it's a little over my comfort level at this time. It's a fairly small system: 8 AI, 4 AO, 16 DI and 32 DO with 3 very fast PI gas flow loops and one slightly slower PI water flow loop. In the past I have used stand alone PID controllers linked to a PC that supervises the loop control and a PLC that cycle valves and other output based on the desired sequencing. The main need now for not using standalone controllers is that the PVs on one of the loops needs to change between three input sensors depending on which portion of the operating sequence it's current running.
Previous experience with "PLCs" includes Fluke 2400 and HP 3852 in the '80s and then various TI's PLC 305,545, and a lot of 315s before Seimens bought them out. Currently have mainly been using about 20 S7-214 to run various test cycles in our main lab. These are set up with hard coded setting for the timers, counters, etc. so that I have no experience assigning variables either from being downloaded or changed programatically with Seimens. Also have experience in 2000 where I installed a DeltaV to a similar type facility but was never completely happy on how well it controlled the gas loops in addition to having a fairly high initial hardware cost. The control was not that tight as I was use to with single loop controllers and was turned off when Fisher/ Emererson said they could correct it for only an additional $4000 consultation visit. Initial sticker shock gets worse when the additional costs keep arising.
So now I'm considering the following options: Siemens 313, another DeltaV system, or AutomationDirect 400 series. From reading previous posts, it sounds like Siemens is not as intuitive to program as some other system, DeltaV is probably a lot of overkill in terms of capability (and expensive to boot), and AutomationDirect appears to not have too many "warts" for being a cheap hardware system.
Realizing these questions may illicit some spirited responses, how would you rate these in terms of:
1) Speed of execution of PID loops - are they all capable?
2) PID autotuning capabilities of each as this system will have a large operating range depending on the testing required. How easy will this be able to apply and monitor?
3) Ease of learning a new system for an experienced engineer/ programmer that has had to learned 15 programming languages in the last twenty-five years. I can learn anything but don't need to learn another dialect just for the sake of being more polylingual. Very familiar with Siemens Ladder and like the SFC I was exposed to on the DeltaV project.
4) Expandability in the future to link this facility to other similar facilities and view/ control/ change programs from anywhere on the globe. This job will be a stepping stone for additional projects that are on the horizon.
