Level Switch Program issue
IdealDan
May 2017
MA
480
Hi Guys,
I wrote a Program on Tank Over fill Protection system. There are Five Tanks/Five Rosemount 2120 Level switch inputs and One Audio Visual Alarm output.
I SET the Alarm with inputs from the Level Switches on the Tanks and RESET all with a Push Button.
Carrying out internal FAT today, I noticed that the Trigger input from the Level Switches remains TRUE so long as the switch is still in contact with the liquid and this renders my code irrelevant.
QUESTION PLEASE:
How can I achieve this? Rising edge don't seem to work here.
I'll Appreciate your supports.
You need to use a one-shot instruction.
I'm assuming the switch goes from off to on and remains on as long as the liquid is covering it. Using a one-shot will require the switch to go from off to on before it alarms again.
Thanks, it worked
dear, i am assigning start/stop levels for the sump pump, i was wondering what is the minimum differential level that can be used when a float...
2,573
Dear all, i have LS1200 murphy used for suction scrubber (connected NC contacts to 1756-IQ16 card) and the question is: when i triggered switch...
1,729
Dear, I am trying to size level switch contact rating for a specific application. we will be using multilin 469 as below...
1,872
Dear, I have a case where a centrifugal pump is sucking from a double compartment tank, usually for the dry run protection of the pump, we use...
7,703
Dear, I am using in a pump control panel a relay connected to a high level switch that will stop the pump in case of high level in the receiving...
2,636
