LM90 on USB port
labingtone
Aug 2002
Manila, Philippines
113
I had install the LM90 Serial Software for GE Fanuc 9030 PLC on Windows 98 O.S. My IBM laptop do not have serial port com, It has USB port only. What i did is to install USB to serial converter, I go to the control panel/Device manager and configure it as com1.
To run this LM90 programmer you must go to DOS PROMPT. When I set up the the software to cummunicate with the PLC a warning message is displayed "CONFIGURED PORT IS NOT AVAILABLE".
I would like to clarify if the DOS environment can not recognize the port I Set up on the windows system. Any information is highly appreciated. thank you
Lm90 can run in win98/2k/xp window
so the USB problem in dos is ofcourse not nessesary
Jonas lets make sure the facts are understood
LogicMaster 90, other wise know as LM90, is a dos based program created to program the GE Fanuc 90 series plc.
Note I said DOS BASED.
GE doesnt support it for use with XP... could be because XP doesnt have a dos base.
Many people manage to get LM90 working under different environments in different ways.
I quit using it when I got VersaPro but have it loaded on this laptop as I speak. I have never seen LM90 run in anything but a dos window, it is dos based, so your statement has me confused.
Lm90 can run in win98/2k/xp window so the USB problem in dos is ofcourse not nessesary
Would you be kind enough to share why a dos based program running in any environment would NOT have an issue with USB or any port besides serial. Please offer specific details.
I am running LM90 with XP and a USB serial port successfully. Right click on the program file and set it up to run in a DOS box. The only problem I have is it only runs on half the screen but apart from that I have not had a problem. Got me out of trouble without having to spend lots on Versa Pro.
beerchug
BobO if you go to Windows Explorer and right click the LM90 exe file then goto Properties then the Screen tab, you can set it for full screen. Sometimes you have to adjust the font to make it actually use the full screen.
I didnt attempt to use lm90 with the XP laptop I had, I got VersaPro.
Converting a 90-70 LM90 to PME 9.5 and need some help with the migration errors and conflicts in the feed back zone. I have parameterized blocks...
831
Having specific issues with migrating a 90-70 PLC from LM90 to PME 9.5. Backing up the LM90 Folder importing into PME is fine however I do not...
866
We have a customer that has 6 machines running GE Series 90-30 PLCs. In order to support them, they bought a used Dell Full size desktop PC with...
1,258
Hello, one of our clients' GE 90-30 PLCs has lost its program - we deal mostly with AB hardware, so we don't have any old GE programming software...
1,251
Hi Every one, I tried to upload from ge 90-30 plc using versapro software, so that i may migrate program to machine edition. when i try to...
1,588
