Load cell Interface with PLC
balajiraja
Feb 2017
Aruppukottai
In my project we are using load cell for monitoring the weight of the unknown materials, and this load cell is interface with PLC for process control system. So we need circuit diagram for this load cell converter circuit of 4-20ma to the PLC...
Don't go for the manufacturing... You will get this ready-made converter card from indiamart. Also It is not recommended to use converter card rather direct PLC interfacing module for accuracy issue. I have used delta make load cell module and interfaced with PLC via MODBUS communication
please answer the following questions.
Load cell manufacturer and model #
load cell amplifier manufacturer and model #
plc brand name and model #
analog input card model #
without this, we can give you hundreds of answers.
did you try google for these part number manuals?
regards,
james
I think i Got all connections now.
my next step is to define unknown materials weights on ladder logic any suggestion or sample idea i can start with?
I have reread your post and I have several questions I think you need to address.
How much weight.
how big of a container - you may need multiple load cells to weigh the storage bin and material.
if you use multiple load cells, you will need to buy an integrated system, ie. load cells and summation controller.
james
All load cell transmitters can accept multiple load cells, either via an integrated summing or via an external summing box.
I have noticed that more brands now does the summing in software. That allows you to monitor single load cells which is invaluable for installation and troubleshooting.
I definitely prefer such a load cell transmitter, placed locally at the load cells - definitely NOT remotely in a control room far away from the load cells.
4-20 mA output is plenty accurate enough for most applications. Otherwise, if you need the native load cell signal - then go for a local transmitter with profinet, profibus, devicenet or similar connection to the controller.
I'm currently working on my 'Weight Sorting PLC Trainer' for my thesis. I am using a thin beam force sensor to determine the weight of my object...
21
7,532
Good Afternoon, I’m limited with a skilled maintenance staff to design and build Load Cell , Rollers , etc. for conveyor sections . Do...
664
Good Afternoon , Does Rockwell Automation have an Input Card , maybe in the 1734 series , or CompactLogix series that will receive signals...
856
Can someone recommend an Intrinsically safe barrier that can be used with an "ANALOG" load cell on a weigh scale? Load Cell is rated to be in a...
1,378
Hello All, I have two bags of two different types of peanuts hanging on a load cell above two separate feeders. I am using Studio 5000 and would...
45
8,852
