logix 5000 bit shift left help
darren1990
Sep 2014
australia
hi,
having abit of trouble getting the bit shift left to work in logix 5000
all is good except it wont accept my array when i verify
It comes up
Error: Rung 3, BSL, Operand 0: Not array element.
Any one else had this problem ?
Welcome to the Forum !
Please post the exact syntax of the tag you're using in the Bit Shift Left instruction, as well as details about what datatype that tag is using.
Usually when an instruction gives you a "not an array element" it means you haven't entered the array element in square brackets [x], but rather some other syntax that points to the whole tag or some other sub-element.
Hi Darren, and Welcome to the Forum!
Is the tag you have assigned to "Array" in the BSL instruction actually an array? i.e. is it a dimensioned correctly? Even if you are only shifting within 1 x 32 bit DINT, it must be an array, and not just a DINT data type.
Example: TAG: MY_BSL_DINT Data Type: DINT < This tag is not dimensioned, is not an array
Example: TAG: My_BSL_DINT Data Type: DINT[1] < This tag is dimensioned, is an array of 1 element x 32 bits
Depending on how many bits you need to shift, you need to dimension the tag accordingly. If you need to shift more than 1 DINT (32 bits), then increase the dimension from 1 to what ever multiple of 32 bits you require.
EDIT: Quick Draw McRoach!
Regards,
George
My data type was just DINT not DINT[1]
and my tag is just Array_Dint
thanks for both of your help, have been googling this for hours!
Darren
Hi, I'm just looking for a simple way to make a button in excel (via VBA I presume) to toggle a bit in RSLogix 5000. I just got FactoyTalkLinx...
606
If any of you wizards can help in this I would be ever more grateful. We have this device that generates 9 second pulses coming into a DI module...
31
3,785
How can I achieve the same functionality in Studio 5000? Image 001.png for the old RSLogix500 program Image 002.png for conversion to Studio...
2,571
Hello, I'm using Compact Logix L33 in RSLogix 5000. I'm trying to message over modbus register that is 16bit UINT. In Rslogix 5000 do I message...
1,573
Hi there, I am accustomed to working with Logix 500 but have a program modification I need to do on a CompactLogix.... I created a timer...no...
2,523
