Logix Motion
DarrylR
Nov 2019
illinois
162
We have a machine with a 1756-L82ES GuardLogix 5580 controller running Logix Designer version 32.12 software. In the program, they are switching between MAJ and MAG (jogging and gearing)on the same axis without any Stop instructions. Is this acceptable common practice?
Yes, this is common practice in some applications.
What they are doing is either superimposing or superexceeding the previous move.
On the MAJ instruction, there is an input called "Merge".
If merge is enabled, the MAG instruction is superexceeded. This means that the MAG instruction is stopped and the MAJ instruction takes over the control of the axis, without executing a MAS instruction. This can be handy if a standstill of the axis is not desired when changing from gearing to jogging the axis.
If the "Merge" input is disabled, then the MAG instruction is superimposed. Which means that you are running both the MAG and MAJ instruction at the same time. This can be very handy sometimes.
I hope this answers your question, otherwise let me know.
Hey guys, On my system, i got prop valve controling cylinder on the left and right to adjust the center of a lumber before it get in a woodmill...
936
Hello everyone, Ho do I go about making changes to a "Motion Axis Parameter" e.g. PositionScalingNumerator that is currently grayed out in the...
1,390
I tried to upgrade my Studio 5000 v32.00 to v32.04 or higher but the install was unsuccessful due to the higher version of Motion Database is not...
1,304
I'm using a 1769-L18ERM to control two Kinetix 5500 servo drives. I am setting up a virtual axis, which I will use the MAJ instruction to run, and...
2,409
Hello everyone, So on Monday morning I'm expecting to have a box of random parts dumped in front of me. I'll create another thread with more...
1,982
