Logix/PowerFlex 525/SICK Encoder
joefox97
Aug 2014
Winter Garden, FL
Hi all,
I've a fun one for you tonight...
I've got a ControlLogix PLC (running v17). I've got a PowerFlex 525 drive with the Encoder Card added on (for an incremental encoder).
And I've got an encoder from SICK. Yes, I know that using an AB encoder would have been easier. Long story (we didn't spec/buy/install that component).
For some reason, the drive isn't seeing encoder counts from the encoder. I have the drive configured for a Quadrature input, the wiring matches both AB and SICK's documentation for A/B channels.
One obvious question that I can't find an answer for in any of the knowledgebase or the almighty Google is whether to configure the encoder as TTL/HTL. The encoder will do either (is programmable). It also has a number of "lines" of resolution which is currently set to the default of 8,192. That seems like it will give me the appropriate resolution.
My question -- what's the special sauce here? How do I make this non-AB device talk to my AB gear and do it's job?
Appreciate any advice/directions/insights into the mystical world of non-AB encoders.
joe
Does the encoder documentation say it's an open collector output? If so, you'll likely need pull-up resistors. You can put a meter on the terminals and see if any voltage appears on them. If not, it's likely open collector and doesn't supply voltage to the AB device.
hello i am trying to set the max frequency for the drive via rslogix 5000, but do not see that patameter in the rslogix 5000 drive paramerts? the...
312
I am controlling a powerflex 525 over ethernet with micrologix 1100, I have the drive set up and running forward and reverse, I would like to...
2,854
Hi all, I have a project coming up with about 25 powerflex 525's on a DLR network. Processor is a 1756-L82ES. In the past, I would have used CCW...
8,129
Hey all, So I have a project that i'm trying to connect 2 powerflex 525's to a micrologix 1100 plc. I would have liked to use a compact logix but...
2,406
Good Evening , What would be the best way to reverse a motor using a Powerflex 525 drive in RS Logix 5000 ? The drive is running in one...
3,973
