Long distance fiber question.
harryting
May 2002
Puget Sound
2,595
I know some folks here deal with long distance fiber so I thought someone can sanity-check this one for me.
Here's the background. Our IT has spare fiber available which I would like to use. However, they said they can't simply assigned them to be because
"Because the distance (~12 miles), special equipment is needed to do the transport and we have to supply those equipment, also, these are *special* fibers that your off the shelf stuff can't handle"
I really, really, really don't want part of the path be under the ownership of IT for obvious reasons. I did a bit of searching and it seems there are plenty of fiber converter or SFP that can handle that distance. I also very doubtful about these "special" fiber claims.
Can someone shed some light on the claims?
It is possible that it is a different type of fiber than what you are accustomed to dealing with. Most shorter run fiber is multi-mode fiber. It's a thicker fiber and light can take multiple different paths down the fiber to reach the other end. Longer run fibers tend to be single-mode fiber. It's thinner and does require different equipment to interface.
I'd ask for a spec sheet as Brian123 said. Failing that, alert management that the IT department want you to spend however many thousands it'll cost to pull a new cable rather than playing nicely.
As far as I know it's either multimode or single mode. SM gets used for long distance. Both are off the shelf items. I have never come across any other type. Do you have access to the converters at either end? Get a make / model off one of those...
There are some special fibers, such as polarization-maintaining fiber, but that is used when you are trying to detect the polarization of light with optical instrumentation. I don't know what IT would be doing with that stuff.
My BS detector pegs when they say it ain't SM or MM cable. I have to wonder if they built all their own fiber modems if they claim off-the-shelf stuff doesn't work.
Hello PLCS.NET! I was wondering if there are options in the market which have distance to tag well as ID of the tag? They need to work in about a...
1,744
Hello, We need to communicate Mitsubishi vfd (E700 Series) of around 32no's over a long distance around 2000meter from Mitsubishi PLC control...
2,940
I have RSLogix 500 standard, And RSLogix 5000 Mini. I want to be able to work with Micrologix and CompactLogix PLCs. Both of the software packages...
2,500
Hello. I have very little experience with PLCs so please bear with me. Problem: We have a pipe with two meter systems that are 10 miles apart...
20
3,166
Good day, Anyone done a PLC to SCADA communication with over 100meters distance. Thank you,
2,757
