Looking for info on improving the stability of hydraulic actuators
s_masiero
Oct 2006
italy
Hello
I'm writing a thesis in industrial engeneering and I need info/documentation on ways to improve stability in a hydraulic actuator. Stuff like working at higher pressure or improving the control system.
I can't seem to be able to find much info on the net, or in my local library for that matter, much less technical documentation.
Any pointers will be appreciated.
You came to the right place
http://www.deltacompsys.com/applications/index.php
Why just improve stability and why does stability need to be improved? Hydraulic systems can hold position very accurately and even move accurately.
It really does seem like you are fishing. Higher system pressures provide more force and more linearity but not stability.
Control systems make a big difference. That is what we sell.
There is plenty of documentation.
If you have specific questions then ask. I can probably point you in the right direction. The main things you should be interested in is the phsyics of hydraulics. This includes things like calculating the natrual freqency. How pressure changes when compressed or fluid is added. How servo valves work.
There are some hydraulic books you can buy written by Jack Johnson or George Keller that are very good. Vickers also makes some good hydraulic manuals. I would visit this site:
Hydraulics and Pneumatics.
http://www.hydraulicspneumatics.com/
They sell the books and also publish a magazine called 'Hydraulics and Pneumatics'. You should find a lot of interesting articles in the article archive.
I am mostly interested in hydraulic motion controllers. You can get the set up software and on-line manuals for our newest hydraulic motion controller here:
http://www.deltacompsys.com/dloads/downloads.php?category=rmc70&mode=navigation
The manual is only 684 pages long but if you skim through it you will see all the things and applications that we have considered. Fortunately one normally only need to read about 5% to get any one application done. It is just that every one has a different 5% and all must be covered.
The page that is most often downloaded off our site is the 'DOs and Don'ts' article on this page.
http://www.deltacompsys.com/applications/technical.php
Here is a directory of movies of hydraulic systems.
ftp://ftp.deltacompsys.com/public/movies
The FTP site is slow so have patience.
I think you have enough to digest for a while. :)
why higher pressure doesn't provide stability?
hi, first i want to thank you for the quick answers and good directions you gave me.
but i didn't understand why you told me that higher pressure doesn't provide higher stability. if you give more pressure to oil inside the actuator, the oil become more rigid so that the less compressibility let the piston become more controllable, isn't it? it should be something like a spring less elastic, may be the frequency improves but with less bandwidht. please correct me if i'm in error but i studied industrial engineerig and i'm not so goog in mechanics
Pressure does increase the bulk modulus of oil effect is so small to be negligible. Other factors are more important like temperature and the amount of air that gets into the oil. In any case the controller can be tuned to accommodate the bulk modulus of oil. It is the changes in the bulk modulus of oil that causes problems and it is air and temperature that causes the bulk modulus of oil to change.
I like to think it makes the 'spring' on either side of the piston stiffer. Again the controller can be adjusted to compensate for the bulk modulus of oil. By your thinking it would be better if the bulk modulus of oil is much higher but that would make controlling pressure almost impossible.
Code:
dp = B * dv / v
Where:
p is the pressure
v is the volume
B is the bulk modulus of oil
What you are suggesting is making B, the bulk modulus of oil, bigger will make the system more controllable. It just means that to change the pressure / force by a given amount requires less oil which means the valves must be much better at controlling the flow of small amounts of oil and still be able to flow the large amounts to actually make the piston move. In other words, increasing the bulk modulus of oil just moves the control problem from the cylinder to the valve. I think the bulk modulus of oil is just fine as it it.
This doesn't make sense. If you improve the natural frequency you will increase the open loop bandwidth. See the spread sheets on this web pages.
http://www.patchn.com/hydrauli.htm
Stability is controlled by the controller and where poles and zeros are placed. The location of the poles and zeros is specified by the tuning parameter.
If you look at the equation for natural frequency of a cylinder you will find that pressure is not part of the equation.
ok, but now i feel a littel confused...! let me explein the whole problem:
I have to write a chapter of my thesis and talk about the STABILITY on a hydrulic actuator. i shoud write:
-why stiff hydrulic are better
-which are the causes of instability in a hydraulic system
(and in this section i would talk about stiffness of oil, stiffness of pipes, entrained air into oil)
-ways to improve stability in a hydraulic system
(in this section i would talk about:-working at high pressure
-improve the control system)
-what happens if i work at high pressure
(in this section i wolud talk about:-design of the pipes
ways to increase forces)
-what happens if i act on the control system
-why it could be the better way to improve stability
-use of robust control
-what happens if control is not enough robust
do you think these sections are enough for the chapter? For my work i need some help on develo these arguments. do you think you can help me?
If you are positioning a mass by push or pulling a spring connected to the mass then would you want to have the spring stiff or weak? You want it stiffer. Systems with a higher natural frequency have 'stiffer springs'.
Do you know what a spring constant is?
Do you know what the natual frequency of a mass and spring is?
Do you know how to calculate the natural frequency?
ftp://ftp.deltacompsys.com/public/PDF/Mathcad - Natural Frequency.pdf
What is your definition of stability? Mine is the tradition control theory version where pole move to the right hand plane or the system as a gain of one with 180 degrees of phase lag.
These are control issues.
[/quote]
[/quote]
Again I don't thingk stability is the right word. I think you are look for natural frequency or stiffness.
Improving the controls will make a big difference but it is hard to compensate for a poorly designed hydraulic system.
Higher pressures do not increase the stiffness or natural frequency. Just the overall gain. Which equation below indicates that?
??? I don't know what you are asking here.
The motion controller does contribute to what I call stability by placing the poles of the system as close as possible to the negative real axis. This results in a critically damped or underdamped response.
Buzz words. Not practical yet. At least not for commerial purposes.
The world begins to shake.
You are trying to take years of info an condense it into a chapter? Will I get the master's degree?
What is the VCCM formula?
What is the formula for natural frequency?
What is the formula for oil flowing through a valve?
What is the formula for the change in pressure as a function of compressing or adding or removing more oil?
What is the operationnal envelope of a hydraulic system?
What is the forumla for a general closed loop transfer function?
When do systems become unstable?
What is a gain margin?
What is a phase margin?
What are poles and zeros?
It seems to me you are not prepared to answer these qestions. You must understand these equations. I have pointed you in the right direction. Now it is time for you to do some research and simulations.
If you insist on saying that raising the pressure will make the system more stable then you will get a poor grade.
hi! thanks for your answers, give me a few days to study the things you've pointed to me and then i will make you more accurate questions. during university i never studied hydraulics so deeply and i want to improve my knowledge with this work. but don't worry, you are giving me a lot of help and you will be one of i will dedicate my thesis to!
Good Afternoon , I am looking for Industrial Ink Jet Printers that mark cases of product with Bar Codes , Lot Numbers , etc. I'm looking to...
2,039
hello all .. this might be Out of the topic but just hope some had come thru or know something about it . looking for supplier for 500L SEED...
1,455
Has anyone used one of these protocol converters like the Redlion or others to get data from Frick RS485 or Ethernet units? Customer has both...
2,895
Hi all We were trouble shooting one of our machines this morning and found a bad prox. switch. We stole (or should I say borrowed) one from a...
4,076
I have a customer with a system that has an open controller in an Allenbradley SLC rack. It appears to be a computer that is sitting in the first...
1,638
