Mac 40+ Mta-100
fids
Jun 2002
manila
22
hi does anyone have an idea how to program the hmi use in a machine. the hmi is communicating with mitsubitsi plc. the hmi used is mac 40+ mta-100. please help me. if you can give me a site where i can download the software and programming manual it would be better. thanks
The MAC/MTA series has been discontinued and support for them is hard to find. When I get to work tommorow I'll dig around and see if I have the manual in PDF somewhere. It is relatively easy to program if you speak Mitsubishi. MPP can be used as well as SW-MTA-WIN. Check with your local distributor. The software is fairly inexpensive. You will also need a programming cable which is basically an rs-232 to rs-422 converter and a plug-in transformer as the MAC-40 does not have an internal power supply. I'll see what I can find in the morning and let you know.
thank you very much for your time. i'm looking forward for the manual. thank you very much again.
Hi, I got problem also with this MTA-100. The machine use MTA-100+FX-20P-CABN+FX2N-32MR. Between hmi and PLC can not communicate each other. I already check to this mta, there is no choice to communication to FX2N, the choice to FX only. If you have the manual book in PDF for this MTA, may i get also? I am sure it will help many. Thank you.
Hi everybody. Can anybody help me where to find a link to download MAC Programmer/SW-MTA for DOS or MAC Programmer+/SW-MTA-WIN for Windows?
I need to UpLoad/DownLoad the program from a MAC 50 operator panel.
Thank you in advance and best wishes
I'm looking for imfor on an old MTA10 I have. I would like to re-program it. But so far I have been unable to locate any software or interface...
3,858
Hi, I have been trying to run drive via Sysmac studio. I can ping the drive. I can see the logic bits going on/off as per command. But, drive is...
21
579
Good morning to everyone on the forum and happy new year. I'm trying to use the following functions in sysmac studio, because I need to enable one...
332
So, here's probably a silly one that I hope someone here knows. I am working with a SYSMAC NA5 HMI. (First time doing anything with Omron.) What...
517
Good morning everyone, I'm having difficulty using the "sin" and "cos" functions in sysmac, in particular the results of the functions are not...
1,163
