MAC 50 Operator Terminal and NC ??
magdyfayad
Aug 2007
cairo
245
I have an Operator Terminal , MAC 50 , TYPE 00701C , which works with PLC from mitsubishi FX 48 MR
I want to know :
1- can this MAC 50 Operator Terminal work with PLC from mitsubishi only , or any PLC and what are they ??
2- I want to use this MAC 50 for NC operation , as I have a machine with two axis and i want to move these two axis by NC operation , can this MAC 50 achieve this requriment or not ??
thanks
The MAC 40 has a number of protocols for different plc's
however this is now obsolete (I think)You need E Designer to program it & dependant on the plc you may need a 5v psu to power the unit (fx supplies this via prog port) + a converter lead to connect to other plc & to be honest the 50 is not built for NC machines, it is only designed for small applications a data entry is rather limited.
HI Like i said i have problem with these two devices. How can i connect mac50 (15 pin male contac) to Fx3u. thanks
1,724
I have a piece of equipment, being controlled by a Mitsubishi FX-80 MR with a Mitsubishi / Beijers MAC 50 connected to it. The system was...
6,666
I'm looking for imfor on an old MTA10 I have. I would like to re-program it. But so far I have been unable to locate any software or interface...
3,851
Hi, I have been trying to run drive via Sysmac studio. I can ping the drive. I can see the logic bits going on/off as per command. But, drive is...
21
571
Good morning to everyone on the forum and happy new year. I'm trying to use the following functions in sysmac studio, because I need to enable one...
328
