MAC 50 Operator Terminal/HMI – Password?
Safebuster
May 2009
UK
I have a piece of equipment, being controlled by a Mitsubishi FX-80 MR with a Mitsubishi / Beijers MAC 50 connected to it. The system was programmed some years ago and the only software I have is that which I have managed to download from the terminal and the PLC using MAC Programmer+ and Melsec Medoc (Basically I’ve had to work out how it operates from this).
My major problem is that the MAC 50 requests a password when changing to another screen (this allows time adjustments) but I don’t know the password! I have downloaded the configuration to MAC Programmer+ but I cannot see the password in the downloaded information? I understand from the manual, that the MAC 50 could be ‘self programmed’ using its own interface, rather than a PC? Is this the way to either read the existing password or set a new one without destroying the configuration/programming of the terminal?
For information, the MAC 50 manual states only this: ‘A password can be allocated to a block here. An entry field is shown where the operator enters a password when a block defined with a password is to be shown on the screen. The password can be any combination of max six numbers and/ or letters.”
Any help would be greatly appreciated.
HI Like i said i have problem with these two devices. How can i connect mac50 (15 pin male contac) to Fx3u. thanks
1,726
I have an Operator Terminal , MAC 50 , TYPE 00701C , which works with PLC from mitsubishi FX 48 MR I want to know : 1- can this MAC 50...
2,218
I'm looking for imfor on an old MTA10 I have. I would like to re-program it. But so far I have been unable to locate any software or interface...
3,851
Hi, I have been trying to run drive via Sysmac studio. I can ping the drive. I can see the logic bits going on/off as per command. But, drive is...
21
571
Good morning to everyone on the forum and happy new year. I'm trying to use the following functions in sysmac studio, because I need to enable one...
329
