Mac 90
exiled
Jun 2002
England
131
Hi there folks,
i have a project at work to convert a beijer mac 90 to a E600 unit. My Q is is there an easy way to convert the current prog.
i am using mac programmer + and E designer along with a cab5 cable.
ive tried opening the mac file with e designer but it just comes up with "unidentified unit" and then i cant see any blocks ect. :(
many thanks
The key to your issue may be SW-MTA-WIN. I'm using version 4.1 and can open a MAC-90 (MTA-G1 in th US) program and save to an E600. Check with your local Mitsubishi rep for the software.
Can you open the program in MAC+ (Mac+ and E-designer are almost the same program)
Or can you upload the program from the HMI with Mac+
I am not familiar with the Mac-90 but I am with the E 600.
Converting may not be straight forward. The E600 might have more buttons and more functions that the mac90.
But, if you can upload the program from the hmi with mac+ it would not take too long to convert it manualy. You could run mac+ and E designer together, swapping from one to the other writing the parameters as you go.
thanks
cheers guys:
goody yes i can open the file from the mac in mac p+ no problem. converting it manually is what i have been doing i just thought maybe there was a way of converting the basic programme structor any then start to debug moving buttons ect.
i'm familier with the e series but not the macs.
Hi, I have been trying to run drive via Sysmac studio. I can ping the drive. I can see the logic bits going on/off as per command. But, drive is...
21
579
Good morning to everyone on the forum and happy new year. I'm trying to use the following functions in sysmac studio, because I need to enable one...
334
So, here's probably a silly one that I hope someone here knows. I am working with a SYSMAC NA5 HMI. (First time doing anything with Omron.) What...
517
Good morning everyone, I'm having difficulty using the "sin" and "cos" functions in sysmac, in particular the results of the functions are not...
1,163
looking for the the MAC address for this PLC, I count find it in the front or at any part of the PLC itself. connected to the PLC by USB, showing...
1,768
