Steve Bailey
Happeeman, you imply that once you've purchased the software, you still have to spend more money. In fact the only additional 'expenditure' is that you have to spend a few minutes of your time on the authorization process. You have to spend time reading the manual in order to properly use the software. Do you object to that 'additional expenditure'?
I've said this before. If you're philosophically opposed to paying for software, then patronize the companies that give it away.
BTW, there would be nothing illegal about you sending me the serial number and site code. The corresponding authorization code would only work on your computer. If I were to use the same serial number to generate a site code for my computer, when I called it in to get an authorization code, GE Fanuc would say "sorry, that serial number is already registered to Happeeman". If I decided to authorize it on my computer first, when I went for an authorization code for you, they'd say "sorry, that serial number is already registered to Steve Bailey".
At any rate, it looks like we'll just have to agree to disagree. You're entitled to your righteous indignation over GE Fanuc's policies. To keep your blood pressure under control, I'd suggest you use some other brand of software in the future. I'm entitled to my opinion that the real reason you started this thread was to try to find a way to make unauthorized copies of the software.
