Magelis XBT-FC0645
bayeibrahima
Sep 2010
DAKAR
188
Hello to all
Magelis XBT-FC0645 is connected to Telemecanique Premium TSX 57253 plc.
Sometime while navigating through the different windows,, the screen sudenly lock; no buttons work.After several ON/OFF power operations, all is OK.
The machine may run during several days without any problem; the screen run fine.
What would be the cause of the sudenly locking of the panel?
Best regards.
There might be some code written in plc on a certain event that writes to the dialog table of the screen that can lock the operation......but it is more likely that it is fault
Wondering if anyone has a manual (pdf file) on Magelis XBT PO22010 or where to download ? Thanks
1,499
Hi, I use a Magelis XBT-N410 (master) to edit alarms from 2 Twido-PLC's (slave 1 and 2) in a Modbus-network. I use the [F1] function-button on the...
2,417
Hi first time posting on here. I was wandering if anybody knows how to solve a problem I have with the Magelis XBT-R410 HMI. The problem is I...
2,085
Hello I have a situation where a XBT-F HMI has lost its program. The program inthe TSX Micro PLC is fine. I have to create an HMI application to...
1,936
We are using Telemecanique PLC combined with Magelis HMI (XBT 023110) with XBT MEM 08 memory card on it. Recently the display (Magelis) has...
4,236
