man my head hurts
I recommend you forget trying to do this with ASCII instructions and spend the money for a BASIC module (or similar). The engineering time you waste trying to get this to work with ASCII instructions coupled to the trouble-shooting time the next time you have a problem 6 months down the road added to the cost of dying your hair (or what's left of it) back to it's original color will more than offset the cost of the module.
Cheers,
(8{)} :) .)
(Yosi)
I have recommended this module before. Prosoft MVI46-GSC.
I using it to communicate with a custom built device.
I use RS-232. But the module can be configured for RS-485.
I send out and read strings of data (using PLC logic)
Setup is fairly easy and Configuration is thought the PLC. The example program provided drops in and works.
With the BASIC module you need separate program using the Basic language.
I replaced the Basic Module with a MVI46-GSC. I made my life much easier.
Has any one out there used this ProSoft module MVI46-GSC????
http://www.prosoft-technology.com/content/download/690/6414/version/4/file/MVI46_GSC_Datasheet.pdf
Yes, so it is not so great of an advantage.
I replaced the Basic Module with a MVI46-GSC. I made my life much easier. Has any one out there used this ProSoft module MVI46-GSC????
It looks like it would solve a bunch of problems for Allen Bradley.
21 to 10...??? In "Lambert" Field??? Sacked... TWICE??? Oooo... I feel the strength once again in the FORCE. It appears, after a long slumber...
2,999
Does anyone have experience wiring this type of analog pressure transmitter up? It's 4 wires. 3 blacks and 1 green which I assume is earth...
270
Hi. Long shot, pretty sure there won't be a lot of people knowing what I'm takling about. SEL G60 Protection relay, I'm not seeing all the...
741
:shoot: Hi, I am looking for a little bit of help : I have Cognex DM 280 barcode reader connected through ethernet to CompactLogix 5380 and...
2,461
Kindly, we have a Virtual Machine Windows XP with many PLC and Drives softwares. The problem is that the Windows is only displaying German menus...
840
