Maple HMI Macro HELP!!!
Cyanogen281
Oct 2013
Houston
I am designing an HMI program that will feature a 3d level. I believe I am on the right track using one picture that contains 26 states (Each state representing a value from the PLC). The problem is I can't figure out how to write the Macro to get this puppy going... Here is what I have so far... I know how to write simple little if then statements but cant figure out how to tie it in with the 26 states of the picture...
Any help or advice would be greatly appreciated.
Hello,
I am do not know about Maple HMI but, if it has a "case" statement it would be orders of magnitude better/faster than an "if then" ladder.
My2c.
The Maple HMI macro language has a Select Case statement which you could used based on the value of a variable. That should work.
The Maple brand is made by Weintek.
You don't need a macro. Do as bwhite said - use a word lamp. Have you built a custom part in the library with 26 states?
Some Weintek macros here.
Example programs on Weintek's website. Make sure you use examples for your model. Unless you have the latest model, yours will be compatible with EB8000 software. The newer ones are eMT and EB Pro.
hello, I have a Maple Systems HMI5103L currently programed and running in conjunction with a AB 2080-LC50-24QWB. everything works fine data is...
728
I've been tasked with modifying a current hmi program for the addition being added to the cell (auto/manual ,I/O ,Status). When I try to upload...
433
Hello everyone, I have a machine I'm working on that has a Maple HMI5070NLv2 and a Micrologix processor. I have the PLC running on RS500 emulate...
1,436
Hello friends, I’ve recently started learning about PLCs and HMIs after I acquired a Wago 750-871 with one digital input card and two digital...
20
5,624
I need to try to get an upload from a Maple HMI 530C-004. Is anyone able to tell me what software I need and where I might be able to find it...
1,579
