When I look at the properties of the slave PLC in the master hardware config DP connectio, it does not contain the full options, this I believe is because the master PLC does not know where the slave PLC is.
It looks at the other PLC's in the project and asks you which to connect to, if there's only one then you will only get one choice.
For thois reason both PLC's must be in the same project.
Open the Siemens example and see what I mean. The master is set as address 4.
