Mdi xr-3000
greggerrior
Sep 2015
nova scotia
currently getting an outrageous amount of false trips on our MDI XR-3000 metal detector, we have it set to the lowest sensitivity setting. we are fairly confident that the false trips are being caused by high metal content in the ore we are processing, does anyone have any suggestions that could solve this issue?
thanks for any and all help.
So you're passing metal ore through a metal detector and don't want it to signal metal is present?
I don't think you're using the right tool for the job.
Maybe a gamma ray spectrum analyse would be better suited. It's what I've previously used in quarrying applications to work out the material content of what was being crushed.
Had a big magnet to pull metal from the conveyor.
I know nothing of this model metal detector. The aperture models I know have a transmitter coil and two reciever coils. The receiver coils are wired out of phase so they cancel each other for a near zero signal. As something conductive or reactive passes through, there's an imbalance in the reciever coils and some level of signal to detect.
Anyway, many problems can be from the mounting framework. Attachment points within the magnetic field must be securely connected or securely isolated. A loose connection in surrounding framework that touches and opens with vibration causes problems. Current loops through the framework making and breaking interfere with the detector. Where practical, we have a single mounting point grounded and the rest isolated. Where there is a loop, make sure it doesn’t intermittently open. Also avoid metal movement near the detector. Make sure guides and chutes are secure with minimal or no movement and are securely isolated or securely grounded.
Another potential problem for us is drifting values of aging components that balance the reciever coils. That would be factory or factory trained service.
I'm struggling to get a stepper motor working. I have it working in inch mode and I can reference the drive and get the sync bit on. When I change...
1,337
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
221
It states WinPcap must be installed for the Emulator to function. WinPcap.org states that the technology is mature with no updates planned. Am I...
862
Good afternoon all, We have a carton machine with 7 Ultra3000 sercos drives controlling various servo motors. From what I understand, It has...
438
Action On Release command Set(ConveyorPopup,ConveyorPop_1) rejected w/ string tags. SetStringTag(index, data) wants an index. How does one pass...
964
