Meaning of "cross-connection"
Cross connection means there are special terminals on the device that allow it to be jumpered to other devices - so you connect your 24v and 0v at one point only.
Hello: One customer has an application using 1715-IF16 on EtherNet/IP for the Rockwell side and HART master for the sensor. Everything is OK and...
1,804
This is in an existing application, so stuff I've found and I'm trying to debug. I've got no Tech support contract, so can't view Tech Notes :/...
1,564
Hey guys So when im online and i look at my tag list Some values show up with a white background some show up as grey What is the difference...
1,186
Hi, Can some explain me what's the measining of this option inside hardware configuration. When should I want/need this option to be...
2,924
Hi guys does any one know what does the specs on electrical wires mean....1sq mm (1/1.13)....what does that specs in brakets mean
1,791
