meaning of symbols in electrical schemas
pavel47
Jul 2005
Lausanne
20
Hello,
I am new in automation. In my actual project I should transfer
old electrical schema (on paper) to CAM software. In this schema I cannot understand the meaning of some symbols. For example there is about 10 different symbols of valves without explication.
Where could I find in Internet some sources with corresponding information.
Thank you in advance for your help.
Pavel.
Hello: One customer has an application using 1715-IF16 on EtherNet/IP for the Rockwell side and HART master for the sensor. Everything is OK and...
1,807
This is in an existing application, so stuff I've found and I'm trying to debug. I've got no Tech support contract, so can't view Tech Notes :/...
1,566
Hey guys So when im online and i look at my tag list Some values show up with a white background some show up as grey What is the difference...
1,189
Hi, Can some explain me what's the measining of this option inside hardware configuration. When should I want/need this option to be...
2,924
Hi guys does any one know what does the specs on electrical wires mean....1sq mm (1/1.13)....what does that specs in brakets mean
1,791
