Melsec + Scada
greatz
Nov 2004
I´m searching for a scada prog. that can communicate with my melsec A3A serieel or with ethernet. Can anyone help me?
First thank you for the reply, but
This version of the software is fully functional with only the following limitation:
1) No networking
2) Runtime limited to 8 hours with virtual I/O or 15 minutes with physical I/O.
You need a key, and those are unfortunately the expensive for a home user.
You did not mention that you do not want to pay for the SCADA package. I do not know of any SCADA supplier that will give you a full working copy for nothing.
Would suggest you will probably have to roll your own.
If you have a Mitsubishi driver that has DDE, you can probably develop one in Excel.
I want to communicate my Q series PLC with Factory IO using GX works 2 software, I want to use modbus as server and the ips are as follows plc...
62
Hi everyone, I have a small project for an industrial site entry gate system. It's running on an old Melsec PLC, and I have a new Shihlin PLC...
154
Anyone have access to Melsec Medoc plus 2.31a that can either open a file (.pcd zipped in link below) and send a PDF/screenshot of the ladder, or...
393
Hello! First time poster and a big PLC newbie so I am looking for some backup here. I have an old Mitsubishi FX-48MR that lost its program...
541
Hi I have a Melsec FX1S-20MR, which has been programmed. I would like to copy the program to a new FX1S-20MR? What are the possible ways to do...
642
