memory latch with a timer
I want to take my foot off the foot pedal after I step on it and still have the timer finish it's cycle.
redmanrh
That is how a TOF or OFF timer works, it starts timing when you remove your foot from the foot-switch, you don't need to seal or latch it in. Sounds like you are just confused on the operation of the timed bits, look at your timer data table while operating the foot-switch and you will figure it out.
I do agree with the others, TON or on delay timers are much less confusing.
Roger
Notice his original logic Roger:
| 0
|---] [---+----------( TIMER )
| | TIMER
| +---]/[-----( 15 )
Whether or not redman understood how an off-delay timer operates, he was still requiring that the foot switch be ON for the valve to fire. The off-delay timer would start timing, but its contact became useless once the foot switch input went false.
beerchug
-Eric
I am not familiar with that PLC but here is
my suggestion:
foot_sw trigger
----| |---[osr]----------( )
trigger timer output
output | | timer
foot_sw : input ("O")
output : output ("15")
timer : on_timer
trigger : some spare bit
[osr] : one shot (rising edge)
You can try to get rid of the first rung
and use input "O" instead of trigger.
in this case however output might stay on
for longer time than specified by timer
if operator decides not to remove foot
from foot switch. when using both rungs,
output would stay on for exactly same time
every time.
I am kind of new to GE products, but we have several in my area. I made a minor logic change and it verified good, but when I tried to download I...
40
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
80
Hi, Yesterday, I was at a customer site. I made one little change. Changed a dummy bool output to an actual output. I didn't add any tags, or...
360
I have a c-more micro with a three digit input box on one of the screens. This is being written to a memory location in a DL05. I don't have the...
116
Hello PLC friends. I've been going through a saga of diagnosing and fixing an old PLC setup that I inherited. I am learning as I go. Initial...
346
