Hi.
I have some (quite basic, actually) questions:
1) Does anyone know exactly what happens when you perform a Memory Reset on a Siemens S7300 CPU?
2) Will you loose data (actual values) configured in a datablock (DB) if you perform a memory reset?
3) I know DB's are said to be non-volatile, but can you risk loosing configured data in an instance DB when you perform a memory reset or if you have a power loss on your system? (for instance, if you have a PID regulator, and configure/change gain, Ti and Td parameter in the instance DB from any HMI)?
4) any other know cases where you risk loosing data in a DB which has been written to (configured) from an HMI?
Thanx in advance
Thanx in advance
