MGD flow to MGD Totalizer . Why did I use Gain?
TheWaterboy
May 2006
-27.9679796,153.419016
1,927
Logix V20
Using FBD I have a totalizer that takes a MGD flow rate and outputs a running MGD that gets reset at midnight.
Time base is set at 1 (Seconds)
Inside this is a Gain of .000694444.
Why would I put a gain in there if I am totalizing the same units?
My belief is that I didn't know about Timebase 3 (Days) when I built it, (since it isn't in the help file), and I came up with that factor to compensate for the time base.
I built a new one to test my theory but i wont be able to compare till tomorrow. In the mean time, Does that gain factor look familiar to anyone?
Maybe this equation has sense for you:
Code:
------- = .000694444
24 * 60
I am trying to setup the TOT function block so that I bring in GPM and want to output MGD. I cannot seem to figure out the correct gain in the...
2,728
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
172
Dear All, I need a sample PLC program to count the output pulse of a mass flow meter so that a specific amount of mass (for example 100gm)can be...
163
Has anyone installed Hp laserjet pro 4203 to OMNI 3000 or 6000 via ethernet..Is there a specific Config? I have a problem..Please advise
60
I can't seem to figure out how to add descriptors to I/O points on an RMC using PCCU. Say, for example, I want to use "Valve_1" as a descriptor...
76
