Micro 820 Messaging
SLJackson
Mar 2014
Portland
I am trying to get a Micro 820 to message with a Modicon M340 Processor via a NOC 0401 card on the Modicon rack. I have the NOC card slave address 1 mapped to the data points I want to transfer which are 40 bytes of info and the MSG instruction in the Micro configured for the same. The two PLCs are connected via radios. All are on the same subnet. I can ping all of the addresses and see everything in an IP sniffer application. I cannot get the Micro to read any of the values that I have set in the Modicon processor. Has anyone tried to do anything even remotely close to this and if so can you point me in the correct direction. Thanks in advance for any help.
Just in case anyone stumbles across this thread and is having a similar type of issue post here as I was able to get this working after a lot of struggles. I would be a bit difficult to explain all of the hoops I had to jump through to make it work but if there are specific questions I might be able to help.
I’m running a micro 820 to measure a tank level, then turning on equipment at certain levels. I have an analog input (4-20) that I’m storing and...
279
Hi All, I came up with this for ramping the PWM pin on the micro 820. I'm new to ladder logic so I am not sure if this will even work? Once...
351
The micro 820 is visible in RS Who when I configure my Ethernet to capture the random IP. I am getting an error when following the steps below...
954
Hi! I need help converting an old MicroLogix 1100 project to Micro 820. Project Details I have an old MicroLogix 1100 program that has been in...
473
