dramill
Hi, I'm working in the mechatronics dept of a Junior college, we recently got some new, micro 820's they are: 2080-LC20-20AWB.
Can these run a mechanical relay? the docs I've been staring at for days seem to say only "relay outs on X terminals" which is fine but all these outputs seem to put out only a single digital pulse (visible on scope). Can this unit do a voltage out of any kind?
These were purchased because of the software environment mainly, but on an SLC 200 or 500 output was output (mostly). Are we missing calls in the new software or is this a hardware problem? The SLC's simply worked if you could achieve communication. Send Help! This must be a simple oversight on our part right?
