Micro 820 serial communication
NASK_SL
Jul 2019
Colombo
I have micro 820 (2080-LC20-20QWB) . I need it to communicate with Arduino.Can I use Modbus serial ? I think voltage level is different(not checked yet) , I can manage it using a IC (Max).
if I need to send a string massage to a arduino from PLC , how can I use CCW?
thank you
In general, you can use the Micro 802 as a Modbus RTU protocol "master", and use function blocks to read and write Modbus protocol registers in a Modbus RTU "slave".
The Micro 820 serial port has a screw-terminal connection with both RS-232 and RS-485 signal levels available.
These are not directly compatible with the TTL signals on most Arudio UART ports. You need a shield or plug-in converter to RS-232 or RS-485.
Which Modbus library are you running on the Arduino ? Which model of Arduino ?
thank you very much for support I wish to use Uno board . could I know if I use MOD_BUS message function block in CCW how set parameters and what need other function blocks?
thank you
Any possibility of using a RaspberryPi rather than an Arduino? If you can use something like a Pi, I can help you communicate with it via Ethernet I/P
geniusintraining and dmroeder thank your support. \
geniusintraining, your pdf only mentions how to configure modbus serial , but I need to know how use function blocks for mod-bus serial communication
dmroeder , I am interesting to RaspberryPi, but 820 have only one Ethernet port, event it doesn't have USB port. therefore if i go with pi I have to get network switch. first up all I need to write complete PLC side , i need to know function block usage
if any body know it please help me
I’m running a micro 820 to measure a tank level, then turning on equipment at certain levels. I have an analog input (4-20) that I’m storing and...
291
Hi All, I came up with this for ramping the PWM pin on the micro 820. I'm new to ladder logic so I am not sure if this will even work? Once...
367
The micro 820 is visible in RS Who when I configure my Ethernet to capture the random IP. I am getting an error when following the steps below...
972
Hi! I need help converting an old MicroLogix 1100 project to Micro 820. Project Details I have an old MicroLogix 1100 program that has been in...
481
