jakeparsons03
Hello,
I am testing a Micro 820 and for whatever reason it won't execute the code. I am toggling inputs but the outputs still show as blue (off) when they should be toggling with the inputs. The controller was faulted but I cleared it and it still won't execute the code. I know with Studio it will only run the main routine (where you normally use the JSRs) but I don't think there is anything like that on CCW. Has anyone run into this?
Edit: it is in run mode. The run mode light is blinking.
Edit 2: A blinking run light means its in program. Learn something new everyday. The issue is fixed.
