Micro 8xx comms
Lemming
Oct 2004
PalmerstonNorth
332
Hi all
Anyone know if the new V6 firmware for the AB Micro 800 PLC's allows the CIP serial comms to be targeted to a station address ?? ie > 2 PLC tied together with serial radio's, and each being able to msg specifically to another PLC... I know this wasn't supported in V4
Also is the CIP serial pass thru feature fixed ??
Going to a site next week with 4 x 800 connected with radio, and want to tidy the comms up if the firmware adds the required functionality..
Cheers
Last I checked micro800 firmware was at 2.012. Not sure where you are seeing versions 4 and 6. Are you talking about CCW version numbers?
I know that updating to V4 from a lesser version is a pain - not easy to do. but achievable
CIP works well but not sure if your issue is solved though
I believe the AB Micro 8xx are re-branded PLC's. Anyone know what they are ?? Have a LSis HMI to talk to one, and it doesn't support the native...
17
9,576
Hi, We couldn’t find anything specific, so am starting a new thread. I’m trying to migrate a config from a ML1400 to a micro820 & am experiencing...
104
I’m running a micro 820 to measure a tank level, then turning on equipment at certain levels. I have an analog input (4-20) that I’m storing and...
288
After updating a panel, I inherited another PLC for my "learning lab". It's a Modicon TSX Micro. I've not worked with a Modicon PLC yet, so I...
140
