I have 2 Micro850 PLCs that I am working on that use MSG_CIPSYMBOLIC blocks to transfer data back and forth. Or at least they were...
Basically the project was a simple IP address change on each controller to add them to a different network. After changing the IP address on the controllers, and inside the MSG_CIPSYMBOLIC block, the program no longer functioned.
I've checked network cabling, IP addresses on the controllers, and inside the MSG_CIPSYMBOLIC blocks, and everything looks correct. Rockwell Automation has been less than helpful, and won't return calls/emails so hopefully you guys could point me in the right direction.
I don't mind getting someone on an hourly support gig if needed, just need to work this problem out.
